increase selected colour in xref palette
Moshe-A
Mentor Mentor
Message 1 of 8
Moshe-A
Guys Hi,
how can i increase selected item (xref) colour in xref palette.
talking about R2017 and up
thanks
Moshe
Accepted solutions (3)
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
"Increase item color" means what please? you want to select another color, or you want more choices than just 256 colors?
Message 3 of 8
imadHabash
would you please describe more your issue ?
Imad Habash
Message 4 of 8
cadffm
I think you can not change the color or fade of this highlighting in xref palette.
Sebastian
Message 5 of 8
dbroad
I don't believe the selection highlight color is user configurable.  If you want more contrast between selected and unselected xrefs, set xdwgfadectl higher or stay away from drawing with the same colors used for highlighting.
Architect, Registered NC, VA, SC, & GA.
Message 6 of 8
Moshe-A
thank you all for your reply
got it, no way to control this?!
Message 7 of 8
hi,  open your options window, go to display tab, in the upper left corner change color scheme from light to dark and your selections will be highlighted more prominently.  the problem is that it is always highlighted in white so when you have a "light" color scheme it doesn't show up.
Message 8 of 8
Moshe-A
thanks you very much for that tip
