Incorrect Plot Scale
scross
Message 1 of 17
scross
I use AutoCAD regularly for personal use but work straight from the drawing and have very little experience with plotting. In this case I wish to have signs printed and need to save to pdf with the correct scale, however, nothing I have evaluated allows me to do this.
I went back to the basics, drew a 100mm square which annotates at 100mm the plot scale is 1:1, the units are mm, the units 1, but the plot output appears to be around 5:1 and, as in 20mm rather than 100mm.
I went to create a custom plot scale but cannot select the option, but if I select 1:10 it plots at close to 200mm but when I go back to the Sign drawing it is scaling different again. I presume there is a simple, logical answer but at the moment I feel clueless.
Stephen
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
@Anonymous Show your work: post your DWG file and the PDFs that you made from it here that show how "wrong" please.
Message 3 of 17
TomBeauford
I don't know of any standard square paper sizes and you need a paper size to plot.
If you're plotting on roll paper create a custom size with the height the same as the width of the roll.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 4 of 17
Pointdump
Hi Stephen,
"...when I go back to the Sign drawing it is scaling different again."
You lost me there. Probably best to post your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 17
ChicagoLooper
Hello @scross
  1. Are you printing from modelspace or layout tab?
  2. Would it be possible to upload an image of the plot window showing your print settings?  (The one you used on your 100mm square that printed at ‘20mm rather than 100mm.’)
Chicagolooper
Message 6 of 17
scross
Thanks for all the prompt responses, and sorry for any confusion.
In response to Chicagolooper, I am attempting to generate a PDF from a layout tab.
I have no idea why but when I click on the viewport it states custom scale 0.1842, which explains why the scale is off by approx a factor of 5, but at least to me, not what process I am approaching wrong. I tried setting the viewport scale to 1, but then the drawing vanished.
Message 7 of 17
TomBeauford
Opened your drawing and all you need to do is set the scale of the viewport to 1:1 for it to plot correctly.
Your Capture.JPG shows you plotting the layout 1 to 1 already. The Model Space scale seems to be the only issue.
2023
Message 8 of 17
scross
Thanks heaps. I think this is where I have struggled in the past with any attempts at plotting - as in why is the model space scale not already 1:1 and how do you set it to that by default. I have looked in options and cannot identify a setting and in the model space I cannot see a setting.
Thanks.
Message 9 of 17
TomBeauford
By Zooming to Extents then setting the viewport scale to 1:1 your drawing was centered at the scale you wanted with two clicks. As Zooming in a viewport changes the viewport scale I wouldn't have been able to fix the drawing with the viewport locked.
Once your drawing is in the position and scale you want it's best to lock the viewport by clicking the lock icon in the status bar at the bottom after either selecting the viewport or switching into the model space of that viewport.
2023
Message 10 of 17
RobDraw
I don't think he meant the model space scale. You are correct in that it is and should always be 1:1. I think he meant the viewport scale, which you've already identified as the issue. Set the VIEWPORT scale to 1:1 and try printing again.
Rob
Message 11 of 17
pendean
Community Legend
Community Legend
@scross None of your layouts are set to a plot scale
You assumed AutoCAD can read your mind 😉
Either select a scale from that bottom icon
Or create a named view in modelspace with CANNOSCALE set to your desired plot scale, then use MVIEW command's NAMED sub-option to create your layout viewports.
Now you know.
Message 12 of 17
WeTanks
Please take a look at this recording.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 13 of 17
dany_rochefort
@scross There is no scale setting in modelspace other than Annotative (which is for the size of text and dimensions).
Message 14 of 17
gkreuter4GRKA
Also, it's not 100mm, it's 100"
Message 15 of 17
scross
Thank you everyone for the great insights and clarifications. It is all my fault, because I only use enough functions to create the drawings I require on the run and do not have a complete enough knowledge of the commands, processes and tools available. What I have done is familiarise myself in part with the functions in the bottom toolbar and the workspace scale is not displayed, so it escaped my perception. I just searched to add it but cannot locate how to add it in from customisation options.
Message 16 of 17
TomBeauford
If by workspace you mean layout the scale is always 1:1, no need to change anything there.
All you needed to do to that drawing was switch into Model Space (where the viewport scale becomes visible below) then Zoom to Extents and set the viewport scale to 1:1.
Hope that makes it clear.
2023
Message 17 of 17
scross
Thank you, I thought I had tried both the Model and Layout space, but clearly not.
Very informative everyone.
