In-Place Block Editor - Orbit Transparency
Looking For Help On In-Place Block Editor Settings.
When in block editor we have the option to set the transparency (brightness) level of all objects outside of the block while leaving the block entities 100 transparent. What I am trying to do is keep all entities outside of the in-place block editor transparent (faded) when I orbit.
As soon as the orbit command is invoked all transparency levels go back to the levels as if I am not in the in-place editor. Please help, this is extremely frustrating when I am creating or modifying large structures with thousands of lines.
Thanx In Advance
S.Faris
Invoke the 3DORBIT command and then change the Navigation Mode, then the transparency will take effect.
Just choose FREE ORBIT and select back CONSTRAINED ORBIT
SALMANUL FARIS
Thanx For The Reply.
Yes, im refereeing to "Edit Reference In-Place"
Thats the long version.
Is there a setting that controls this?
j.palmeL29YX
Don't use the Visual Style "2D-Wireframe". Use "Wireframe" (or an other instead), so it works as you expect. Avoid Visual Style 2D-Wireframe.
cadder
Jürgen Palme
