Hi. in AutoCAD 3D, I press-pulled a shape to a certain value.
I want to modify that pull to a different value.
How do I do that ?
Thanks.
How do I do that ?
Thanks.
Hello @stephane_armand
To increase the extrusion of an object, use the "PRESSPULL" command, select the object, and enter the desired height. To decrease the extrusion, use the "PRESSPULL" command, move the cursor downward, and enter the reduction distance preceded by a hyphen (e.g., "-2") to indicate the decrease. I hope that helps 🙂
Thank you very much. I angled so I could select the pulled area and could modify it with the Presspull button.
Not sure why I couldn't do it before.,
Thanks.
Cheers.
Hi and Welcome to AutoCAD Forum,
Click on below image to see how by PRESSPULL command you can modify the extrusion for solid objects.
Imad Habash
