impossible to add custom paper size
paul_margerie
paul_margerie
I want too plot a plan which is 297x2930mm. I was able to print the same file without issue on my old computer (AutoCAD 2022) but on the new computer it do not work :
If i click one of the two "use a custom paper size ..." I direclty come back to the plot window but with plotter : None and papersize : empty
if I try to add it mannully it do not find it after saving and i cannot print test page:
0 Me gusta
Responder
Soluciones aceptadas (1)
416 Vistas
4 Respuestas
Respuestas (4)
CGBenner
@paul_margerie
Hello, and welcome!
Are you still on Acad 2022?  What kind of printer/plotter are you planning to send this plot to?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
0 Me gusta
paul_margerie
Hello
Thanks a lot for your anwser. I was still on AutoCAD 2022 and it was working. I just turned to AutoCAD 2024 and it doesn't work anymore.
I was using "DWG to PDF.pc3" but I also tryed "AutoCAD PDF" and some other. No one was working (always the same reaction).
0 Me gusta
Wojty1
Hello @paul_margerie
Maybe there's something wrong in the Configuration.
Would you mind sharing both of your plotter configuration files (from ACAD 2022 and ACAD 2024)?
And maybe your drawing too (you can delete all objects in model space and paper space, just leave the layout you would like to print.
If you don't know where to find your plotter config files, just publish your drawing as eTransmit (it will create a zipped file with everything needed to open the drawing). You can also open the resulting ZIP file and just copy the plotter config (*.pc3) files.
One question: Which versions do you use in both of your AutoCAD installations - Imperial or Metric?
If they differ, maybe there's some "translation" issue from Meters/Millimeters to feet/inches.
Windows 10 Pro 64-bit | Civil 3D 2024 / Revit 2024 (64-bit EN)
ASUS Maximus Hero VIII / Intel QuadCore Core i7-7700K / EIZO FlexScan EV2411W 24" + EV2416W 24" / 64 GB Corsair Vengeance LPX (4x 16 GB) Dual-Channel DDR4 / 12 GB ASUS GeForce RTX 3060 OC V2
Windows 10 Pro 64-bit | All Autodesk Products 2023 + 2024
HP ZBook Fury G10 / Intel Core i7-13850HX / 3x Lenovo 24" / 128 GB RAM / nVidia RTX Ada 3500
paul_margerie
Solución aceptada
I just found the solution to my problem. AutoCAD could not write the .pc3 file. The solution was to create a new .pc3 file and .pmp file in the temp ordner and to used them to print.
Thanks for your help
0 Me gusta
