Importing .sat or .step, and creating viewports with minimal lines in AutoCAD
We use a program called Codeware Compress to create pressure vessels.
We can then export the 3D model from this program as a recognizable format, to then import into AutoCAD.
I've been told that .sat is recommended first, then .step, then x_t.
My issue is that no matter what file type I use to import, when I switch to either hidden, wireframe, or 2D wireframe visual styles, there are dozes of lines all over this model, much of them unnecessary for what I need to dimension for my final drawing.
I've tried commands such as exporttoautocad, purge, and explode to see if that would help simplify the model, but those don't seem to do the trick.
I would love to do a screen share, to dive into this a little more, to see if there's a way around fixing this, besides hiding, and deleted lines on the ortho views on the paperspace.
I would think there's a way to clean this up directly on the model first.
[This post has been edited for clarity by cheryl.buck]
