Importing from CADWork into AutoCAD
No aplicable
After importing a dwg file saved at 1/4" scale (from CADWork into AutoCAD), I have not been able to figure out how to adjust the settings to allow for further revisions. As an interior designer, I need to be able to add furniture layouts, as well as, add appliances and cabinetry throughout a dwg file that I receive from an architect/designer. Please advise.
0 Me gusta
Responder
1.469 Vistas
6 Respuestas
Respuestas (6)
chriscowgill7373
What kind of adjustments do you need to make to be able to make revisions?  Can you please provide a little more detail in that area, any screenshots of specific items could be helpful as well.
The drawing seems to be made up of normal Autocad linework. You get a warning when first opening the file that it was created using a Student version of AutoCAD, but I'm not seeing any functionality I wouldnt expect to see in a drawing.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
0 Me gusta
imadHabash
what do you mean by " settings " ?
Imad Habash
0 Me gusta
No aplicable
Sure. So, specifically, the dwg imported, however, when I begin drawing out appliances, etc. 36" is much much smaller than it should be with respect to porportion. For example, a 36" wide refrigerator in plan is tiny. The dwg file has much larger measurements. Is there a way to adjust this?
0 Me gusta
chriscowgill7373
your drawing looks like it might be scaled up by a factor of 25.4  metric to imperial conversion.
Almost as though it was drawn in mm, but when brought in the units are being used as inches.
0 Me gusta
imadHabash
you need to SCALE your drawing . try to scale with Reference to adjust your CAD objects . >> Click << also you may need to check your INSUNITS
Imad Habash
0 Me gusta
Patchy
It was using decimal, go to units and change it to ft & in.
0 Me gusta
