Importing Attributes from Excel
Greetings All,
I have more than 100 drawings, where I need to make multiple changes in Title block information. Using EATTEXT, we can export the attribute information from multiple drawings to Excel. Is there some way by which we can import attribute values updated in Excel back to respective drawings?
Thanks.
Samir.
Otto
Hello samir.joshi and welcome to the Autodesk community!
It looks like you are looking for information related to datalinking between AutoCAD and Excel. Community members with similar questions found the following article(s) useful:
DATALINK (Command)
To update data links, use the DATALINKUPDATE (Command)
To provide an interface to external database tables use:DBCONNECT (Command).
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
cadwomen
Hy
my this one ..
look / search for
UpdateTitleblockV1-9.lsp
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Edwin.Saez
You can do it in the following way:
  • use the command "ATTOUT", ask you where to save the .txt, then select the block and export the information with all the attributes in the .txt.
  • open the .txt with excel, and there you can edit the information. The block will have a "HANDLE", which is a unique identifier of the block (a code)
  • when you have done the changes, you save the file in the same format .txt, then from autocad use the command "ATTIN", you will ask for selections of the file you edited, and automatically update the block according to the changes you made in the txt .
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
Jonathan3891
The one posted by @cadwomen was created by @Lee_Mac and is found here.
It may be useful to visit his page to see a demonstration of how it works instead of trying to fumble through it.
Jonathan Norton
Blog | Linkedin
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I haven't used the lisp routine mentioned in this thread but I know that ATTIN as mentioned by @Edwin.Saez works really well. I would try it on a sample set of files to see if does what you want.  This will be a tedious task though regardless.  If you try the LISP routine please add a post on how it worked for you.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
