IMPORTING AN AUTOCAD ARCHITECTURE FILE INTO SKETCHUP
melissacohen
melissacohen
I have an autoCAD architecture file that I received from an architect.  I used it to create my kitchen layout, etc.  I cannot import it into Sketchup where the walls, doors, window, etc. show up.  I tried saving it as a 2013 file, I tried changing the presentation settings, any other ideas?  I know I can save it as a PDF but I prefer importing the dwg file.
ennujozlagam
try to save your drawing into much lower version of autocad before import to sketchup and see if helps. thanks
imadHabash
Before you import a file, it's helpful to know what CAD entities SketchUp Pro does and doesn't support and how to prepare your CAD file for best results. please read more info from here . >> Click <<
Imad Habash
melissacohen
that did not work, as I tried to save in version 13.  But I "exploded" the drawing and that did the trick.
thanks,
pendean
Community Legend
Community Legend
That's pretty much what that document in the link noted, in case you did not know, ADT is an old name for AutoCADARCH
HTH
