I don't know if someone can help me with this but here's my problem: I need to import many pages from a PDF file to make a base plan out of it. But when I use the PDF import, it only import it as an image and not vectorial object as it would do with other PDFs. My question is : Is it possible to import it as a modifiable block/objects or it depends on the PDF itself, like AutoCAD don't recognize it as a plan drawing so it import it as an image only.
Thanks for the help
Thanks for the help
Solved by JBerns. Go to Solution.
It completely depends on the source PDF contents as to what AutoCAD will bring in.
So, i can't do nothing about it and have to trace over it basically. That will take a little longer than expected.
Correct, unless you can find a vector format PDF. Is this something you found online?
Its an As-Built plan set from our client, that was scanned presumably. So not directly printed in PDF from AutoCAD. Do you know if there are some scanner that could scan the original plan set in a vertor format, like those who can recognize writings ?
Could you use the AutoCAD Raster Design toolset (RasterCAD) to convert any of the PDF?
https://www.autodesk.com/products/autocad/included-toolsets/autocad-raster-design
Some great comments below as usual. I have experienced the same thing. someone in production printed out a legit PDF. afterwards they SCANNED it to a PDF and sent it to me. that would not work out as far as providing graphics to be worked with. If production generated a PDF, say from AutoCAD and sent it to me and I performed a ......
INSERT>PDF UNDERLAY>IMPORT AS OBJECTS, this certainly would provide real graphics that i can work with. Although the fidelity of the graphics can be a tad skewed, its close enough for getting the bulk of what i need down. I can always firm up the areas dimensionally as I have a need for it.
Based on the info provided in the other comments, it will be interesting to discover options for images.
Good Luck.
Good Luck.
