Announcements
Importing 3D dwg into SketchUp
I'm experiencing problems with importing 3D Cad files into SketchUp. When i import the dwgs, some components are missing, I'am not experienced in  3D AutocCAD and the DWGs are from a furniture manufacture that i'm using in my project. Any adivce?
3D CAD Files https://mega.nz/#F!Wg5CDQwZ!vs5lC8cZR6dX-IB5K6qz8w
Many thanks
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I took one of the sample files and exploded all the blocks in it. Try this to see if it comes into SketchUp better.  I don't have a copy to try it on here but perhaps this is the issue.
I see that the manufacturer is using a lot of Regions instead of 3D solids so perhaps that too might be part of the issue.
Please let me know the results.
John Vellek
pendean
Community Legend
Community Legend
You need to be asking in the SketchUp forums here https://forums.sketchup.com/, as Autodesk does not hostt support for another company's products, even if your objects pass through Autodesk software.
Are you using SKetchUp PRO, the paid version, or the freebie 'make' variant? Read here about what can and cannot be imported into SketchUp from AutoCAD plus other tips https://help.sketchup.com/en/article/3000165
Thanks for helping but no its pretty much the same as before. (please see attached)
SketchUp Pro
john.vellek
Hi @Anonymous,
Yes, it appears that SketchUp doesn't like regions. Try this drawing. I converted the elements to Surfaces and then use SurfSculpt to turn much of it into solids. The parts that aren't watertight needed to be smoothed and then given a thickness to make them solids. Once this was complete it came into SketchUP
John Vellek
