using autocad 2018 i am trying to import pdf files so i can save as dwg. each time i select a pdf file a window comes up saying only V7 and V8 DGN files are supported.????
Solved by cadffm. Go to Solution.
Solved by imadHabash. Go to Solution.
Solved by john.vellek. Go to Solution.
Hi @dennysbyhp,
Are you able to type in PDFIMPORT to bring the PDF into AutoCAD? Can you share the PDF so I can try on my side?
there is two commands DGNIMPORT and PDFIMPORT ... please confirm that you're use pdfimport.
I am trying to import a pdf as well. I go to the PDFIMPORT icon (under Insert) and choose file to select my PDF file. I select Vector Geometry, Solid Fills & TrueType fonts. I select all options under the "Import Options" and use PDF Layers. I have tried selecting the image of the pdf and also not selecting the image. When I select OK, I get an error message that says "No objects were imported". I will admit this is the first time I have opened ACAD in a couple of years. I work exclusively in Revit, so not sure what I am doing wrong. Image attached.
