Import or Open a TIN file in Vanilla AutoCAD 2018
No aplicable
Is it possible to import or open a TIN file in Vanilla AutoCAD 2018?
I have tried TINSERT which took me nowhere unless I am missing something.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.604 Vistas
7 Respuestas
Respuestas (7)
Alfred.NESWADBA
You mean a triangulated surface file? Then you need AutoCAD Civil 3D, Vanilla AutoCAD can't import it.
If you mean something else then please let us know what the content of the file is, the software which created that file and maybe best: upload the file so we can test it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
Its a triangulated surface file...
Can I use a plugin or maybe try a different file extension?
0 Me gusta
Alfred.NESWADBA
I don't know if there exist any plugins which can do that (as I have Civil3D). But you might search >>>here<<<.
If it' only a one time job than you can upload your TIN file here and I create import it with Civil 3D, the questions I have then:
  • What do you need ... just triangles?
  • Which version of AutoCAD do you have.
- alfred -
Alfred NESWADBA
0 Me gusta
TerryDotson
There are various creators of a .TIN file, I can think of (3) off the top of my head.  For example if there is a companion .PTS file, it's an old Land Desktop surface.  If it's possible, zip and post your file(s) and we can tell more about it.
chriscowgill7373
Solución aceptada
I agree with everyone else.  You cannot natively bring a tin into Vanilla Autocad without the help of 3rd party software or a vertical application.
Having a sample file would make it easier for us to advise you what might be the best option for getting the data into the drawing you need.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
No aplicable
This will be an ongoing thing so I have asked the bean counters to spend some cash..
Thanks for the reply
0 Me gusta
TerryDotson
Make sure you throw that the right way.  Check with the source of the TIN file for the name of the application that created it, then make sure the application or add-on you acquire will definitely read the file (unless it's the same application that created it of course).
0 Me gusta
