Import FBX with textures
Message 1 of 63
I’m trying to import some FBX files (like this sample attached) to AutoCad 2017 and I can’t get the textures. This FBX file originally was an OBJ file created in another software then I decimated it with Remake and then exported to AutoCad FBX format. I guess that the textures are embedded into this file.
Remake / AutoCad
AutoCAD
So, when I import in AutoCad I can see it find 1 material (image bellow) but It is shown grayed. I tried to change view properties to conceptual, realistic, but I got no results. I also tried to find the material at materials list with no results.Capturar.JPG
Why am I doing wrong? Is it possible to see FBX textures in AutoCad. If it is not possible what file format should be able to do it?
Replies (62)
Message 2 of 63
same. see material in list.  only fbx loads in (like your pics)
Message 3 of 63
john.vellek
Hi @Anonymous,
The FBX file should bring in materials as described in this article. I just talked with my 3DS Max expert. We looked at your file and while it had Materials mapped, he suggested that since the Textures are stored externally that since they don't appear to be present, then perhaps AutoCAD won't even really bring in the materials.  Do you have access to the original files?
John Vellek
Message 4 of 63
I've just imported my FBX into cheetah 3d. making sure it had NO other surfaces or jpgs in same folder.   perfectly can see surfaces.
Can NOT see surfaces in fusion 360 (don't care)
and cannot upload to  a360 viewer, perhaps its the cloud services problem above.
but yes  Cheetah 3d.  no other surfaces attached or included.  and fbx has surface.
Message 5 of 63
ok.  i got an fbx into a360 viewer.  no photographic surface.   this is a stand alone fbx file. no other jpgs. or mtl to read.
in cheetah 3d. it has a photographic surface.
conclusion the photographic surface Has to be in the file.
why won't  auto cad read that material ???
(or a360viewer but i don't care)
thanks in advance for reply.
Message 6 of 63
anything folks ?
Message 7 of 63
john.vellek
HI @Anonymous,
My computer went belly up this AM so I dont have access to much. My 3DS Max guy, @Alfred.DeFlaminis was able to get the Texture file from the FBX file. Perhaps remapping  it in AutoCAD will do the trick.
He also found some strangely averaged Normals in the file and has corrected them.  He indicates that 2 textures are missing as well: normal and displacement map.
Perhaps if I could get access to the original OBJ file it would tell us more.
John Vellek
Message 8 of 63
@Alfred.DeFlaminis  you want me to attach the fbx file ?
its 60mb.
how does one remap an fbx  in auto cad ?
Message 9 of 63
Alfred.DeFlaminis
Hello @Anonymous,
It would be my pleasure to extract any maps I can from the FBX and get them back to you.  If privacy is paramount you can PM me a link to the files otherwise you can attach them to a post in these forums.  I can get them back to you within an hour or two (within normal business hours) and I am happy to do so.  Regarding rebuilding in AutoCAD that is a bit outside my area of expertise but John likely has some ideas about that.  Thanks very much!
Best Regards,
Message 10 of 63
@Alfred.DeFlaminis@john.vellek    at John,  No idea what to do w those separated maps ?   are there instructions here on the boards ?
Alfred.  thank you !   maybe wait to see what John says ?    nothing private.  cheers !
Message 11 of 63
john.vellek
Hi @Anonymous,
I am not aware of any method to remap these materials in AutoCAD. If you open the Materials browser on the imported file, it shows only the one Global material.  I think that to examine this more carefully it would be helpful to see the OBJ file. I am guessing that from 3DS Max the file could be opened, checked for integrity and then exported more cleanly for import into AutoCAD.
John Vellek
Message 12 of 63
Alfred.DeFlaminis
Hello @Anonymous,
It may be that AutoCAD doesn't deal with that many maps, but the least I can do is extract them and attach them for you in the case you need them in the future.  Just let me know!  🙂
Best Regards,
Message 13 of 63
first of 3 files
Message 14 of 63
2 more
Message 15 of 63
cant upload the   .mtl file ?   @Alfred.DeFlaminis  ??
you need it yes ?
Message 16 of 63
Correct the highlighted errors and try again.
  • The file 22.90._simplified_3d_mesh.mtl does not have a valid extension for an attachment and has been removed. 3dp,3ds,ach,ai,art,ass,asx,avi,axm,bm,bmp,cfz,chm,cps,csv,dbf,dcl,doc,docx,dst,dwf,dwfx,dwg,dws,dwt,dxf,dyf,dyn,eco,env,eps,esri,f3d,f3z,fbx,fm,gif,gz,gzip,iam,ics,ide,idw,iks,ipn,ipt,jfif,jpe,jpeg,jpg,log,lsp,mac,max,mb,mp4,mpg,msg,nc,nc1,nwc,nwd,nwf,obj,obk,pat,pc3,pdf,pkt,png,png,ppt,pptx,prj,psd,rar,rfa,rft,rlf,rtd,rvt,sat,sdf,sdf,sdf2,sdf3,shp,shx,simstudio,sldasm,slddrw,sldprt,step,stl,stm,stp,svf,svg,text,tif,tiff,txt,vcf,vtf,vtfx,wmv,xls,xlsx,xml,xps,zip are the valid extensions.
Message 17 of 63
Alfred.DeFlaminis
Hello @Anonymous,
If you want you can rename it to .zip and I'll rename it again.  Or what I do in a lot of cases is put everything in a folder and make a zip out of the folder.  Either way I'm flexible.
The thing is though that .obj's don't contain the texture information, so there are no maps to extract.  FBX's can contain it however.  But I can take the obj and apply the map if you'd like and export as FBX.  Is that what you're looking for here?  Thanks!
Best Regards,
Message 18 of 63
thanks so much.
all i want for Christmas is the fbx to open up in  Autocad w surface.
however you'd like to accomplish.
will send FBX as well as last Obj file the MTL w different end file name. zip.
cheers !!
Message 19 of 63
@Alfred.DeFlaminis  will you let me know if you need to use OBJ or any of those files or you are working purely w
the FBX ?
(be super cool if you worked with FBX)
attached is the FBX only openin in CHEETAH 3D.   without any accompanying obj files.
Message 20 of 63
Alfred.DeFlaminis
Hello @Anonymous,
Sure no problem.  I have imported the .obj, embedded the texture, and re-exported as FBX for you.  This obj was 1M polygons which might be heavy for AutoCAD but I've exported as FBX anyways.  🙂  I compressed as .zip using 7zip.
For some reason it's a much bigger file as an FBX, possibly because of the texture being embedded.  I reimported it as a test in 3ds Max to make sure the texture stuck and was tiling properly and it was.  Getting it into AutoCAD with proper tiling is a bit outside of my area, so John will take it from here.  Thanks so much!
Best Regards,
