import/export filters
No aplicable
Hi All,
I have Autocad 2017 and i am trying to export and import filters from one file to other, but i cant.
I have seen that in Autocad 2015 there are bottoms to do it in the layers properties manager but in 2017 are missed.
Anyone could help me?
Regards
0 Me gusta
Responder
Soluciones aceptadas (1)
588 Vistas
6 Respuestas
Respuestas (6)
cadffm
You probably saw a picture of the LayerPropertiesManager vertical programms like MEP ACA Civil3D example link
AutoCAD does not have this feature, You need an additional program. (Example)
Sebastian
No aplicable
So, which is the best solution for this?
autocad should have any way to do it?
which is the program you told me?
regards
0 Me gusta
cadffm
At least I do not know a direct way in AutoCAD.
Did you ask for an additional program?
I have posted a link to you: (Example)
Reference is made to LFILTERIO by DotSoft as an example.
Hope it helps
Sebastian
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
There is no built-in way to do this in plain AutoCAD. There are likely routines that will help you achieve this though. I suggest checking in the Customization forum, the Autodesk App Store, and a little web surfing to find a few.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
No aplicable
Thank you for your help
0 Me gusta
