Import an Image to Autocad
No aplicable
How can we import an image to Autocad and keep its original coordinates?
0 Me gusta
Responder
480 Vistas
4 Respuestas
Respuestas (4)
rudi.roux
Hi There,
Are you talking about simply adding an image in AutoCAD with its original image size attributes(dimensions)?
OR are you looking to place an image in AutoCAD from a Map with a specific Geo Location?
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
No aplicable
Place an image in AutoCAD from a Map with a specific Geo Location.
0 Me gusta
rudi.roux
Here is step by step information on How To Set Geographic Location from a Map
Here is information on how you can capture a Rectangular Area of the Online Map
Please note that you need to be signed into Autodesk 360 in order to use the Online Map Function.
Rudi Roux
LinkedIn
rudi.roux
Hi there,
If you found that my previous post resolved your issue/query, please mark it as a solution so that others could benefit from it in the future.
Rudi Roux
LinkedIn
0 Me gusta
