Import a STP file into AutoCAD 2016
wai1954
wai1954
G'day,
I have been provided with a STP file that has come from a client using Inventor.
I open a drawing (nothing in it and no template) and go Import and then pick the STP file in question. I get the alert telling me that the file is being processed in background and I can check the icon in the lower right of the screen to see progress. Eventually I get a message come in the corner telling me the file is ready for importing, but how do I do anything with it?
If I pick Import all that happens is I go through the same process and nothing on screen.
How do I import it?
Thanks.
wai1954 (Ian A. White)
Alfred.NESWADBA
In that dialog you find a link, click that link 😉
If you have told the import-dialog that a block should be created, then you would not see anything in the model-space as long as you don't run command _INSERT and insert that block into the model-space.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
HI @wai1954,
Alfred is correct that when you do your import you have the option of importing it as-is or inserting it as a block. If you choose the latter it can be a bit deceptive. It actually creates the block inside your drawing but does not insert it.
John Vellek
