I am relearning AutoCAD. When inputting imperial units I used to be able to enter 10-6 for 10 feet 6 inches. I am currently using AutoCAD 2024. However, when inputting a dimension I have to include quotation marks (i.e. ' for feet and " for inches). How do I enable the system to just take 10-6 without having to waste keystrokes inputting the quotations?
Solved by paullimapa. Go to Solution.
When set to Architectural units AutoCAD's Imperial distance entry has always been 10'6.
Though you can drop the inch ["] mark you cannot drop the foot ['] mark.
The only times a hyphen [-] is used is to indicate a negative number or a fraction like 10'6-1/2
Glad to have helped…cheers!!!
