Image not showing in AutoCAD
I just put this image in my CAD file to trace it yesterday, saved the DWG, and reopened it today to this. How do I fix it? I also just tried to delete the image and then reinsert it, and I couldn't get that to work either! Can someone give me some very simple directions on how to fix this?
lakshmankumar.satya
imadHabash
HI,
from Xref command a palette will appears , from saved path press the dots to re-path your image and see if any changes.try to put the image in the same place that your drawing exist.
Imad Habash
Mark_C_123
just move the image to the same folder as the dwg and re-open it. 🙂
ennujozlagam
hello, don't xref your image if you don't cclick full path the next time you open your file your image is gone. you try to follow this methos. thanks
