Image Frame Command on embedded image
Accounts_FPG
Accounts_FPG
Hi
I'm updating a drawing border with the company's new logo I want to imbed the image which I have done through select and copy from paint then paste special on CAD. I want to use image frame to get rid of the border as it doesn't look right in the space I have can anyone help?
cjneper
Set IMAGEFRAME variable to 0.
Or if you have Map, use the MAPIFRAME toggle.
Is that what you are looking for?
Patchy
If it is OLE you set OLEFRAME to zero.
and Regen.
Accounts_FPG
Hi
Thanks for this I managed to get it to work with OLEFRAME. Image frame would not work because it was embedded. Cheers for your help.
Accounts_FPG
Spot on thank you 🙂
