Anuncios
ID Tag Help
ID Tag Help
No aplicable
I've been given a sheet set that needs to have room id numbers modified. I cannot click on the id tag and edit directly because it seems to be linked to an external document but I can't figure out how to find the document. Is there a way to trace the layer and id tags back to the external source document?
0 Me gusta
Responder
403 Vistas
1 Respuesta
Respuesta (1)
natasha.l
Hello @Anonymous,
You can use the DATALINK (Command) to pull up the Data Link Manager, there you can locate the file to the linked information. AutoCAD Data Linking
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
0 Me gusta
