Anuncios
I need urgent help : error: misplaced dot on input
No aplicable
When I try to use Lisp, when I load it I get a message like the picture and it doesn't work. I enclose the Lisp file and screenshots, please help
0 Me gusta
Responder
Soluciones aceptadas (1)
431 Vistas
4 Respuestas
Respuestas (4)
ennujozlagam
you can refer to this LINK and see if helps. thanks
0 Me gusta
ВeekeeCZ
Solución aceptada
Where did you get that file from? Is it yours? Or colleagues? Are you aware of what all it includes? It's a lot.
I've tried to fix it but did not run it.
Also, not sure which type of langueage script was originally used, it makes a mess in the Latin alphabet - that was also the cause of the issue. See
(setvar "modemacro"(strcat"·ąŔĚľî<$(getvar,clayer)>Á÷±ł$(GETVAR,ORTHOMODE) S=1/$(getvar,DIMSCALE)""$(edtime,$(getvar,date), YYłâMOżůDDŔĎ DDD ))
No aplicable
It's Korean
0 Me gusta
No aplicable
thank you so very much for your help
0 Me gusta
