I need to draw an array with variable step.
Hi!
A few days ago I installed autocad 2016.
So, I am new to this program.
I am drawing the guitar fretboard.
The image is attached.
There is no special function in array command.
How do I achieve the desired result?
thanks!
Patchy
There was classic Array and new Array started in 2012, neither has the ability to array with increament.
If you want to know if 2016 has changed the array feature, Google search.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
https://www.youtube.com/watch?v=M2LVetKMNRA
Draw them where they should be, you're not building a spaceship for NASA
Kent1Cooper
The frequency relationship between adjacent half-tones, and therefore the ratio between fret positions, is based on the 12th root of 2 [an octave is a 2-to-1 frequency ratio, and it's 12 half-tone steps].  See the attached drawing.  It's with the string length from Bridge to Neck end being 1 unit, not an actual guitar's string length, so you will need to scale the whole thing to your actual string length.  And the width of the neck and string spacing are arbitrary, and not specific to a guitar or anything else -- it's just the fret spacing in relation to the open string length that's relevant.  But the principle for fret spacing is applicable to any fretted instrument [mandolin, bass guitar, banjo, ukelele, lute, viola da gamba, etc.].
And no, I'm not aware of any capability built into AutoCAD that can do this for you directly in anything like an Array command.  But it might be possible to draw some curve that you could divide regularly in some way and project from the divisions to get the right fret positions.
Kent Cooper, AIA
I've drawn sevral fret boards
  Here's a link to Stumac site and a calculator fto find the dimension of fret boards.
You can use the offest command to make your fret locations
Hope this helps.
https://www.stewmac.com/FretCalculator
Ron
Guys, thanks for reply!
@Kent1Cooper,
as far as I understand I should create function which will distribute frets.
Could you advise me on tutorial?
I even don't know what is the name of the language used for programming in autocad
Thanks, again
Kent1Cooper
@Anonymous wrote:
....as far as I understand I should create function which will distribute frets.
I could put together a routine that would go through the steps for you automatically and lay out all the fret lines in one command, using the code in the Text in my drawing, but I already did lay them out [at least for the number of frets on the guitar in your picture], and since the relationship will always be exactly the same in terms of spacing between the ends of the open strings, you can just take the fret lines in my drawing and copy them, scaling them collectively to match the open-string length of whatever you're drawing, no matter what instrument or size it is.  Use somewhere on the Bridge line as the base point for Scaling, and since the open-string length in the drawing is 1 drawing unit, you can use the distance to the Neck-end line directly for the scale factor.  [Or the other way around -- Neck-end line as base point, distance to Bridge line as scale factor.]
AutoLisp is the main language for making this kind of custom routine in AutoCAD [there are other ways, too], and the code in my drawing is written in it.  If you want to look for tutorials and sources for learning how to use it, do a Search in the Customization Forum for things like "Learning AutoLisp" or "Lisp tutorials" or similar wordings -- there are many threads asking for such sources, and many suggestions and links.
Kent Cooper, AIA
Thanks!
I'll try that!
Guys, I do appreciate your help!
