i need help please!!
pedrommarreiros77
pedrommarreiros77
pedrommarreiros77
IT DOES THIS EVERY TIME I TRY TO PLOT TO A PRINTER. IF I PLOT TO PDF IT IS FINE BUT I NEED TO PRINT STRAIGHT TO THE PRINTER??? CAN SOMEONE PLEASE HELP ME?? 🙂
Smiley Happy
pedrommarreiros77
Smiley Happy
Alfred.NESWADBA
which printer (and driver) do you use on what operating system?
Make sure you have the current printer driver and it might help to recreate a new PC3 for that printer using the AutoCAD internal plotter manager.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pedrommarreiros77
I have windows vista and it is an hp laserjet 1536dnf mfp.
Sent from my Samsung Galaxy smartphone.
martti.halminen
Explanation for the error code in https://msdn.microsoft.com/en-us/library/cc231196.aspx :
0xC0000374 STATUS_HEAP_CORRUPTION A heap has been corrupted.
In this case some other program (likely your printer driver) has written in AutoCAD's memory area. Try getting another printer driver.
If you want details, try http://blogs.msdn.com/b/jiangyue/archive/2010/03/16/windows-heap-overrun-monitoring.aspx
[No, I've never read that thoroughly. When we hit that error on 64-bit Windows 7 and AcadM 2012, running AutoCAD in Vista compatibility mode was the trick that helped for that case]
pedrommarreiros77
I deleted the printer and reinstalled it and downloaded the new driver and
it seems to be working 🙂 thanks for the help 🙂
