I need better defined edges when rendered
When rendering objects have poorly defined edges. I find its more present when using colors like white and black. Is there a better way to go about showing these colors without having one part of an object blend into the other?
leeminardi
Would you post a sample of the poorly defined edges?
lee.minardi
the render isn't the highest quality but the whites turn out like this each time. any suggestion?
(this is a marketing req for a proposal, i am not a pro at visuals on AutoCAD)
leeminardi
Two obvious things to try are increasing the resolution  (pixel height and width) and the render quality setting (the default is Medium).
lee.minardi
