Anuncios
I'm Unable to draw with proper dimensions
No aplicable
Hello
The problem I'm facing is that, whatever I draw, a line for example, I select the first point, select the direction, then when I set a proper length, the point is just fixed to where it was when I was entering the length. When I click, to complete the line, the line stops at the point where I click and it's length is not taken into consideration. This makes it impossible for me to draw properly.
This happens to other shapes also. Like circles. Please help me to figure out this problem. Thank you
0 Me gusta
Responder
308 Vistas
3 Respuestas
Respuestas (3)
Patchy
Hit the F12 key and see, or your input distance doesn't match the unit setting for your drawing.
0 Me gusta
imadHabash
Try to turn OFF your Dynmode [ F12 ] .
Imad Habash
0 Me gusta
Kent1Cooper
I don't think dynamic input is the issue.  Maybe this is a dumb question, but just in case....  Are you typing in a distance and completing entry of it with an Enter/space?
Kent Cooper, AIA
0 Me gusta
