I'm confused here.
I'm confused here.
john.p.addy
Message 1 of 14
I'm confused here.
john.p.addy
I'm in working on ACAD 2023 and trying a simple command.  Offset.  I have attached a .dwg file.  The P-line in Red I can offset it to the opposite side of the white lines it does it just fine.  When I try to offset it to toward the white lines it won't offset, which is the way I'm needing to offset it to.
I'm confused why it won't offset the way I'm needing it to go
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
Replies (13)
Message 2 of 14
Jason.Piercey
Try closing the polyline first.
Message 3 of 14
john.p.addy
IT IS CLOSED !
Thank you,
John Addy
Message 4 of 14
Jason.Piercey
Message 5 of 14
Jason.Piercey
Examine the intersection/common vertex at the lower left curve and horizontal segment.
Message 6 of 14
john.p.addy
OK then please explain what you mean by close it.  I just went an hatched it with picking a point and it hatch as you see here.  If the pline wasn't closed then I wouldn't have been able to hatch it by just picking a point.
Thank you,
John Addy
Message 7 of 14
cadffm
CLOSED or open is a property of polylines.
How many corners for a rectangl?
A Rectang needs 4 vertex and CLOSE
or the stupid rectangle needs 5 corners (5 vertex, the 1st and the 5th on top og the 1st)
Sebastian
Message 8 of 14
john.p.addy
Please explain how to close the pline then.  Ive never heard of this before.
Thank you,
John Addy
Message 9 of 14
Jason.Piercey
The PEDIT command has a close option but in this case it adds another curved segment. Instead grip the end of the curved segment/vertex I mentioned before and snap it to the end of the horizontal segment. It offsets fine (even though it is technically still "open") if you use the close option after snapping the segments it still offsets without issue.
Message 10 of 14
TomBeauford
You've always been able to hatch a polyline by just picking just a point. You can even use a hatch gap tolerance to hatch one with a gap.
Just pick the polyline an close it in the Properties Palette.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 11 of 14
Jason.Piercey
Also, the HPGAPTOL system variable may be of interest to you.
Message 12 of 14
john.p.addy
actually I zoomed in very close and The intersection/common vertex at the lower left curve and horizontal segment.  The curve was not connected to the end of the line.  I did get it connected but and was able to get it to offset
thank you for your help.  I have never came across that before, usually it happens when don't close all the way and you can see it.  not where the plines are over lapping.
Thank you,
John Addy
Message 13 of 14
Valentin_CAD
@john.p.addy ,
Note the two grips at the lower left and an extra line at the bottom. Correcting this will help.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 14 of 14
cadffm
That wouldn't be part of the first hour of (my) schooling polylines, but of the second.
Select the line, change property CLOSED to Yes
But you should also DELETE the useless Vertex 37 and edit the bulge of vertex35-36
Sebastian
