I found the trial folder, and I want to it gone but...
不适用
1,161 次查看
8 条回复
1 条消息(共 9 条)
不适用
Okay, so I'm trying to clear up some space on my hard drive and I found the trial folder of AutoCAD 2017 - English. Just so I won't bug out the software itself, I'm asking if it's okay to delete this folder permanently when I already activated the program?
0 个赞
1,162 次查看
8 条回复
回复 (8)
2 条消息(共 9 条)
Patchy
Did you install it in 2017? that would make it more than 3 years for trial, it shouldn't run anyway.
0 个赞
3 条消息(共 9 条)
不适用
No, I installed it just last year. My laptop couldn't reach the minimum requirements of the new versions then, so I downloaded the version that it can.
So... I can delete the trial folder without problems?
0 个赞
4 条消息(共 9 条)
Patchy
Check and see when was the files modified or accessed to be sure they are junks.
Then use windows, make a restore point, delete the folder.
If things go bad, restore it.
0 个赞
5 条消息(共 9 条)
pendean
Community Legend
Community Legend
You need to uninstall the software first in Windows, then you can delete the program folder: here is the full process if you wish to avoid more messes in your underpowered laptop https://knowledge.autodesk.com/customer-service/download-install/remove-products/remove-windows-prod...
0 个赞
6 条消息(共 9 条)
不适用
Hmmm... The program was a bit slower when I put the folder in the recycling bin. Not sure what file it needed but I'm looking at all of the files. So far, the most recent ones are the date I downloaded it last year.
0 个赞
7 条消息(共 9 条)
Patchy
The installation file doesn't do anything once Autocad is running.
0 个赞
8 条消息(共 9 条)
不适用
Okay. I checked my downloads first and sure enough, I don't have the installer of AutoCAD2017 but I have Autodesk Download Manager. Just to be safe, I'm just going to download the installer again and find my license number and key. Then I'll do what you suggested. Thanks for the help.
0 个赞
9 条消息(共 9 条)
不适用
okay then. thanks for the help.
0 个赞
