i don't open file autocad
Help me i don't open file cad
Accepted solutions (4)
pendean
Community Legend
Community Legend
Use RECOVER command to fix your file, it have many problems
i was used recover command but file don't open. you can fix problems help me.
Alfred.NESWADBA
Which version and service pack of AutoCAD do you have?
If you have a vertical product like AutoCAD Architecture or Mechanical or Civil 3D, which one?
(otherwise sending a repaired dwg for AutoCAD 2018 might result in you can't open it 😉 )
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
Any reason you could not use the file I reposted in my last reply?
john.vellek
Hi @Anonymous,
I, like others used RECOVER to look for errors in the file you provided.  During this process it appears that there are so many corrupt entities that many are removed from the drawing entirely.
I found that Purge and -Purge>Regapps also cleaned up the file quite a bit.  I have attached my version of your file but compared to the drawing preview, most of the content is no longer in the file.
Do you have another copy of the drawing? Perhaps in a backup?
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
