I cant revolve the circles inside of this drwaing
goantamihai
Message 1 of 14
goantamihai
Hello guys i cannot revolve the circles in inside of the drawing. Is there anything i can do? The outskirts i will extrude but when i try to revolve the two circles inside it says "unable to revolve selected objects". Any help would be appreciated i am new to this
Accepted solutions (3)
Replies (13)
Message 2 of 14
Valentin_CAD
@goantamihai ,
Read more about the REVOLVE (Command)
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 14
goantamihai
i tried but i still did not understand that much. I have to do it because it is required in high school but i have never been very good at this
Message 4 of 14
Valentin_CAD
@goantamihai ,
I think you should be looking into other commands like UNION, SUBTRACT, ECT... to obtain something like:
Consider looking at the 3D tutorials from here:  Webinars: Build Your AutoCAD IQ
Emilio Valentin
Message 5 of 14
Patchy
Something like this:
Message 6 of 14
goantamihai
would it be possible to make the inner circle at 360 degrees and 270? I need this for high school and that's what my teacher said it should be
Message 7 of 14
Kent1Cooper
REVOLVE applied to a Circle can be used to make this kind of thing:
[full] or
[partial].  So I assume from the drawing that's not an appropriate command for what you want to do.
Kent Cooper, AIA
Message 8 of 14
goantamihai
i mean i tried it in class and it didn't work so basically my teacher just told me to figure it out. but she said the two circles inside need to be revolved one time at 360 degrees and one time at 270 while the outskirts extruded at 10
Message 9 of 14
goantamihai
also is it possible for you to give me this in .dwg?
Message 10 of 14
Valentin_CAD
@goantamihai ,
I think you would benefit more if you learn to use the JOIN, EXTRUDE, UNION, and SUBTRACT commands (which is what you need to recreate).  You can always come to this forum when you have questions.
Emilio Valentin
Message 11 of 14
Kent1Cooper
@goantamihai wrote:
.... she said the two circles inside need to be revolved one time at 360 degrees and one time at 270 while the ....
I suspect what they need is to be used as Paths for SWEEP or EXTRUDE commands.
Kent Cooper, AIA
Message 12 of 14
goantamihai
would it be possible to give me kinda of a step by step on how to use them?
Message 13 of 14
Valentin_CAD
@goantamihai ,
Here is one way - step by step,  (read about the commands and practice).
Drawing is attached.
Emilio Valentin
Message 14 of 14
Washingtonn
