I cant change the ctb
renatadiassp03
Observer Observer
renatadiassp03
Observer
Observer
Every time I try to change the plotting style it stays the same, no matter what I do, it won’t change, it says it changed but when I plot it it stays the same, is there anyway I can change thay?
Valentin_CAD
@renatadiassp03 ,
Guide us in your process (step by step).
Provide a Screencast or image of the issue.
A suggestion is to use "Page Setup Manager" and check your selection in the "Plot options".
Also, checking the "Display plot styles" will provide a better visual on screen of how it will plot.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
ChicagoLooper
Did you click ‘Apply to Layout?’ Did you SAVE the dwg after Apply to Layout?
Chicagolooper
ennujozlagam
set everything first paper size, what to plot, ctb.....etc then add a new name then apply to new layout? thanks
