I cannot draw a line vertically?
Message 1 of 13
I am unable to draw a line vertically.
Which one of these setting at the bottom will change this?
Replies (12)
Message 2 of 13
Patchy
Use TOP
Message 3 of 13
Kent1Cooper
Normally, by "vertically" one might mean either upward on the page, or upward in the Z direction, which in plan view would up off the page.  In the image, upward on-screen and upward in the Z direction would be the same, because you're apparently in the WCS but in front view, with Z pointing upward on the screen, which means you're drawing in the plane that you're looking at edge-wise.
If you don't have OSNAPZ turned on [which will restrict drawing to the Z=0 plane], you can draw a vertical Line in that view by giving it "@0,0,YourZcoordinate" for the second point.
Or, you can change the UCS to match the current View, and [being careful about where the current plane is in relation to the WCS -- it might also require a UCS Origin setting] then draw normally.
Kent Cooper, AIA
Message 4 of 13
pendean
Community Legend
Community Legend
You're looking a the FRONT of your model: so "vertical" means you want to go in the Z direction (your cursor is only moving in the plan x and Y directions, neither is vertical). Is that your intention?
Message 5 of 13
victor.dambergAU5PZ
Observer
Observer
I have the same problem, I want to draw a straight line in the z direction but it is not possible. I'm viewing my model from "Left".
Message 6 of 13
Valentin_CAD
@victor.dambergAU5PZ ,
Type, UCS and then select View:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 7 of 13
Kent1Cooper
Even without changing the UCS, you should still be able to do this, just not with the cursor.  If you're still in the WCS but viewing from some other-than-plan-view direction [or even if you are in plan view], to draw a vertical-into-Z Line 123 drawing units upward from the starting point:
LINE
[give it a start point, then type in:]
@0,0,123
Kent Cooper, AIA
Message 8 of 13
pendean
Community Legend
Community Legend
@x,y,z is how we would all o that all the time: have you had a chance to use that yet?
Message 9 of 13
victor.dambergAU5PZ
Observer
Observer
Thank you, this works, but will it affect anything else, must i undo this when I want to draw a line in another direction?
Message 10 of 13
victor.dambergAU5PZ
Observer
Observer
Do you mean to include the @?  Otherwise it will draw a line to point 0,0,123 near origo.
Message 11 of 13
victor.dambergAU5PZ
Observer
Observer
When drawing a line I'm not able to choose "relative" as when you for example move an object.
Message 12 of 13
Kent1Cooper
Do you mean to include the @?  ,,,.
Yes.  If you have dynamic input on in a new-enough version of AutoCAD, it's not necessary, but still works; if you have that off or are in an old-enough version, it is needed.
Kent Cooper, AIA
Message 13 of 13
Valentin_CAD
If drawing in different direction other than X, Y, then input the X,Y,Z values instead - as suggested by others.
Generally, most users draw with UCS and PLAN in World, see this link:
Emilio Valentin
