I can't install Autocad 2017 on my new computer with Windows 10
Message 1 of 12
Hello! I have been already trying for two days to install Aytocad 2017 on my new computer but without success! I'm desperate and I don't know what else I could try! Here is the installation log file:
2016/7/26:12:42:31 nefel DESKTOP-OG6DGGU === Setup started on DESKTOP-OG6DGGU by nefel ===
2016/7/26:12:42:31 nefel DESKTOP-OG6DGGU Path_Length: 162
2016/7/26:12:42:31 nefel DESKTOP-OG6DGGU Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/7/26:12:42:31 nefel DESKTOP-OG6DGGU Launch
2016/7/26:12:42:31 nefel DESKTOP-OG6DGGU CommandLine /PK 001I1 /SN 900-25511725 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/7/26:12:42:31 nefel DESKTOP-OG6DGGU Current Directory C:\Users\nefel\AppData\Local\Temp\_AI41C4.tmp
2016/7/26:12:42:33 nefel DESKTOP-OG6DGGU === Setup ended ===
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU === Setup started on DESKTOP-OG6DGGU by nefel ===
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU Path_Length: 162
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU Current Directory C:\Users\nefel\AppData\Local\Temp\_AI41C4.tmp
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU Launch
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\nefel\AppData\Local\Temp\_AI41C4.tmp\Setup\AcSetup.dll
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/7/26:12:42:32 nefel DESKTOP-OG6DGGU PageOpen LaunchDialog
2016/7/26:12:42:39 nefel DESKTOP-OG6DGGU PageOpen LicenseDialog
2016/7/26:12:42:39 nefel DESKTOP-OG6DGGU PageOpen ProductInfoDialog
2016/7/26:12:42:39 nefel DESKTOP-OG6DGGU PageOpen ProductSelectionDialog2
2016/7/26:12:42:43 nefel DESKTOP-OG6DGGU PageOpen FullProgressDialog
2016/7/26:12:42:44 nefel DESKTOP-OG6DGGU Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/7/26:12:42:44 nefel DESKTOP-OG6DGGU Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/7/26:12:42:44 nefel DESKTOP-OG6DGGU Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/7/26:12:42:44 nefel DESKTOP-OG6DGGU Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/7/26:12:42:44 nefel DESKTOP-OG6DGGU Install Universal C Runtime (KB3118401) Succeeded
2016/7/26:12:42:45 nefel DESKTOP-OG6DGGU Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/7/26:12:42:45 nefel DESKTOP-OG6DGGU Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\nefel\AppData\Local\Temp\vcredist_x86_2015.log
2016/7/26:12:42:46 nefel DESKTOP-OG6DGGU Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/7/26:12:42:46 nefel DESKTOP-OG6DGGU Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/7/26:12:42:46 nefel DESKTOP-OG6DGGU Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\nefel\AppData\Local\Temp\vcredist_x64_2015.log
2016/7/26:12:42:47 nefel DESKTOP-OG6DGGU Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/7/26:12:42:47 nefel DESKTOP-OG6DGGU Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/7/26:12:42:47 nefel DESKTOP-OG6DGGU Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/7/26:12:42:50 nefel DESKTOP-OG6DGGU Install DirectX Runtime Succeeded
2016/7/26:12:42:51 nefel DESKTOP-OG6DGGU Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/7/26:12:49:57 nefel DESKTOP-OG6DGGU Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/7/26:12:49:57 nefel DESKTOP-OG6DGGU Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/7/26:12:49:57 nefel DESKTOP-OG6DGGU Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/7/26:12:49:57 nefel DESKTOP-OG6DGGU Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/7/26:12:49:57 nefel DESKTOP-OG6DGGU Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/7/26:12:49:58 nefel DESKTOP-OG6DGGU PageOpen InstallCompleteDialog
2016/7/26:12:50:02 nefel DESKTOP-OG6DGGU === Setup ended ===
2016/7/26:13:21:49 nefel DESKTOP-OG6DGGU === Setup started on DESKTOP-OG6DGGU by nefel ===
2016/7/26:13:21:49 nefel DESKTOP-OG6DGGU Path_Length: 162
2016/7/26:13:21:49 nefel DESKTOP-OG6DGGU Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/7/26:13:21:49 nefel DESKTOP-OG6DGGU Launch
2016/7/26:13:21:49 nefel DESKTOP-OG6DGGU CommandLine /PK 001I1 /SN 900-25511725 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/7/26:13:21:49 nefel DESKTOP-OG6DGGU Current Directory C:\Users\nefel\AppData\Local\Temp\_AI33D3.tmp
2016/7/26:13:21:51 nefel DESKTOP-OG6DGGU === Setup ended ===
2016/7/26:13:21:50 nefel DESKTOP-OG6DGGU Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/7/26:13:21:50 nefel DESKTOP-OG6DGGU Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/7/26:13:21:50 nefel DESKTOP-OG6DGGU Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\nefel\AppData\Local\Temp\_AI33D3.tmp\Setup\AcSetup.dll
2016/7/26:13:21:50 nefel DESKTOP-OG6DGGU Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/7/26:13:21:50 nefel DESKTOP-OG6DGGU PageOpen LaunchDialog
2016/7/26:13:21:59 nefel DESKTOP-OG6DGGU PageOpen LicenseDialog
2016/7/26:13:21:59 nefel DESKTOP-OG6DGGU PageOpen ProductInfoDialog
2016/7/26:13:21:59 nefel DESKTOP-OG6DGGU PageOpen ProductSelectionDialog2
2016/7/26:13:22:03 nefel DESKTOP-OG6DGGU PageOpen FullProgressDialog
2016/7/26:13:22:04 nefel DESKTOP-OG6DGGU Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/7/26:13:22:04 nefel DESKTOP-OG6DGGU Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/7/26:13:22:04 nefel DESKTOP-OG6DGGU Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/7/26:13:22:04 nefel DESKTOP-OG6DGGU Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/7/26:13:22:04 nefel DESKTOP-OG6DGGU Install Universal C Runtime (KB3118401) Succeeded
2016/7/26:13:22:04 nefel DESKTOP-OG6DGGU Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/7/26:13:22:04 nefel DESKTOP-OG6DGGU Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\nefel\AppData\Local\Temp\vcredist_x86_2015.log
2016/7/26:13:22:05 nefel DESKTOP-OG6DGGU Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/7/26:13:22:05 nefel DESKTOP-OG6DGGU Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/7/26:13:22:05 nefel DESKTOP-OG6DGGU Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\nefel\AppData\Local\Temp\vcredist_x64_2015.log
2016/7/26:13:22:06 nefel DESKTOP-OG6DGGU Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/7/26:13:22:06 nefel DESKTOP-OG6DGGU Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/7/26:13:22:06 nefel DESKTOP-OG6DGGU Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/7/26:13:22:09 nefel DESKTOP-OG6DGGU Install DirectX Runtime Succeeded
2016/7/26:13:22:09 nefel DESKTOP-OG6DGGU Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/7/26:13:29:42 nefel DESKTOP-OG6DGGU Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/7/26:13:29:42 nefel DESKTOP-OG6DGGU Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/7/26:13:29:42 nefel DESKTOP-OG6DGGU Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/7/26:13:29:42 nefel DESKTOP-OG6DGGU Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/7/26:13:29:42 nefel DESKTOP-OG6DGGU Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Please let me know if you can help me with my problem!
Replies (11)
Message 2 of 12
JDMather
Download the two install files from the Autodesk Virtual Agent.
Message 3 of 12
I just tried and I got this error:
An error occurred while processing your request.
Reference #50.9f4dcdd4.1469531850.7df100
Message 4 of 12
JDMather
Try http:\\manage.autodesk.com and select Browser Download (slowest) (works).
Message 5 of 12
the browser download just finished and I tried to open the file and I got this message which you can see on the following image :
Message 6 of 12
And I really have to add that the download had already finished!!! What is eventually wrong with my pc?????
Message 7 of 12
JDMather
Delete this (red line) you don't need it.
You should have two files that look something like this (your error image is covering them up, but I can partially see that you have them).
Double click on the 001_002 file and then follow the on-screen instructions.
Message 8 of 12
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
If you performed the last download properly you should have two files that are necessary for your install.
Before you run them, I suggest you perform a clean uninstall of any prior failed installations [See description of steps here]
Please also see this post regarding Best Practices to ensure that you next installation is successful.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 9 of 12
Hello again. The thing is that I couldn't download the files that you thought I have. I replied above that when I tried to download the dlm 001 and 002 files I got the error:
The files you saw behind my error image were these in the following image ( the simple autocad files that I can't install). So dead-end again I suppose...
Message 10 of 12
JDMather
Those are not the files that I am suggesting you get for a painless install.
What do you see when you go to http://manage.autodesk.com ?
Post screen shot.
See Posts #4 & 8
Message 11 of 12
That's the screen I see. But I have opened the downloads beyond the Autocad and I have also tried to download the browser download (slowest), if that's is what you intent to suggest....
Message 12 of 12
Well I just did it!!! Thank you both!!! I'm going to continue with the installation of 3ds max. I hope I won't have further problems, but if so, I am sure that I can count on your help! I am really grateful!
