I ask for help. The autocad falls on startup
No aplicable
Please advise. Autocad 2014 will normally start. When I want to insert an object, or something from RIBON will fall. I have WIN 10 Creators. Previously he worked perfectly. Thanks for advice
0 Me gusta
Responder
Soluciones aceptadas (1)
385 Vistas
3 Respuestas
Respuestas (3)
ВeekeeCZ
Read THIS. Acad 2014 in Win10 is not such a good idea.
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
AutoCAD 2014 is not compatible with Windows 10. I suspect that you had it installed and updated your OS to Windows 10 and then recently applied the Creator update.
I suggest that if you had it working prior to the Windows update, that the real fix is to rollback the update.
Otherwise, it might be time to upgrade to the current version. You can get a free trial here.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
Have you tried rolling back the update? Did this fix the issue with your AutoCAD 2014?
John Vellek
0 Me gusta
