I am unable to zoom out in Autocad. It keeps getting stuck!
This widget could not be displayed.
Hi everyone!
Hope you're all doing good!
I am working on Autocad 2007, and have set the limits lower 0,0 and upper to a larger coordinate & the unit is set to millimetres.
For some odd reason, I am unable to zoom out!
Kindly help!
Thank you!
Kent1Cooper
Welcome to these Forums!
There's a maximum to which AutoCAD will Zoom out without a drawing Regeneration.  But if you REGEN when it's as far out as it will go, you will then be able to Zoom out much farther.  You don't say whether you can't Zoom out at all, or just can't Zoom out all the way.  You can Zoom to the limits -- give it 0,0 and (getvar 'limmax) for the window to Zoom to -- and answer Yes when it asks "About to regen -- proceed?"
Kent Cooper, AIA
socnandan
Try REA
Your drawing might need to regenration.
pendean
Community Legend
Community Legend
Learn to use REGEN or REGENALL commands when that happens: that's how it works so far.
