Hyperlinks in Autocad to PDF
joe_kohli
Message 1 of 16
joe_kohli
Not sure if this can be achieved but I will ask to see:
Can you add a hyperlink (say you add the hyperlink to an object in a drawing) in an AutoCad, then convert that drawing into a PDF and save it on your work station... then open that PDF, my question is this: will that hyperlink work? Or is there a way to achieve this action within the PDF?
My goal: to hyperlink all pdf's so they can be one big continues drawing by clicking the hyperlinks that will open you up to another drawing (or in this case, PDF).
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
What have you tried so far where it did not work? Explain your process in detail please.
Remember, you will need to know ahead of time and add the correct hyperlink to the external file yourself to the object(s) before creating the PDF. The program does not do that for you in any way.
Message 3 of 16
joe_kohli
@pendean I believe I answered my own question. I essentially created a hyperlink via AutoCad and then exported that to a PDF. This allowed the PDF to still read the hyperlink which is what my goal was. I then added hyperlinks in my drawing where needed and linked them to various drawings that I needed and then converted it all to PDF so I can move around on the PDF to various other PDF's. Hopefully that makes sense.
Message 4 of 16
ctalosig
I am having problems with this same process.  i created an mtext of the dwg sheet page on a keyplan.  I am creating 3 different sheets and in each keyplan I created the hyperlink to read where that file resides.  Afterwards, i created a pdf of all sheets and the mtext doesn't appear on the keyplan.  What am i doing wrong?
Message 5 of 16
pendean
Community Legend
Community Legend
@ctalosig wrote:
...and the mtext doesn't appear on the keyplan...
What does that mean please? Is your MTEXT just on a noplot layer? Assigned a color that is invisible? Your PDF reader reported an error of some sort?
Message 6 of 16
ctalosig
I started created mtext on a layer to plot on my keyplan.  I have 3 boxes as an example with the text of the dwg sheet on them.  Example, 201, 202, 203.  I typed hyperlink and sellected the text to find the file of that dwg for all 3.  After doing this, i created a pdf of all three sheets and on my keyplan the mtext did not appear on the pdf and of course with the text not being there i couldn't sellect it to see if that hyperlink would jump to the page of where that dwg is on the pdf.
I have been searching on how to do this everywhere.  All i'm finding is adding a hyperlink to a website which isn't what i want.
Message 7 of 16
pendean
Community Legend
Community Legend
@ctalosig
1) Is your MTEXT just on a no-plot layer?
2) is your MTEXT assigned a color that is invisible when printed?
Show us by sharing DWG and PDF files please.
Message 8 of 16
ctalosig
no it is on a plot layer.  creating the mtext was what i was told to do.
Message 9 of 16
CodeDing
@ctalosig ,
After checking pendean's recommendations,
be sure this box is checked:
Best,
~DD
Message 10 of 16
ctalosig
Am i not suppose to use mtext?  What i'm trying to do is from cad files, plotting to a pdf set, i want some type of hyperlink to jump from whatever page i want to jump to.  As i mentioned an example is like a keyplan.  If i want to go to a dwg file, i know a hyperlink can jump to that page in a pdf.  Does this make sense?  How do i make a hyperlink from cad to jump to the file/pages in a pdf set.
Message 11 of 16
ctalosig
Thank you!  I will give this a try and hope this is what i needed to resolve my issue.😊
Message 12 of 16
ctalosig
ok..so i already had that properties checked for hyperlink.  The text is showing up but the hyperlink isn't working.  What am i doing wrong?  Or a better question is, how do i create hyperlinks on cad to work on a pdf set.  Again, this is like the example i had explained where a keyplan that shows several files, i would like it to work when i hover over that keyplan on one file that it would jump to that page.  Can someone please help me to do this?  It doesn't seem it's my settings that is a problem here.  It just looks like I'm missing a step or something.
Message 13 of 16
CodeDing
@ctalosig ,
Can you post a DWG file (or multiple files if necessary) for us to look at? We need more information.
Works for me:
Paper space before PDF plotPaper space before PDF plot
PDF, cursor hovering over hyperlink to DWG filePDF, cursor hovering over hyperlink to DWG file
DWG file opened when clickedDWG file opened when clicked
Best,
~DD
Message 14 of 16
ctalosig
I'm done for the day but will post tomorrow.  i did get it to work but it created a dwf file.  i prefer a pdf file.  will send more info tomorrow.  thank you.
Message 15 of 16
ctalosig
This is a continuation of the previous messages that is now not allowing me to respond to it.  So i am attaching a dwf file where the hyperlinks on the keyplan works on sheet G04 where it will show 3 other text and when i click on them it will go to that pdf sheet.  This is what i am wanting to happen but on a pdf.  So this dwf was created from my cad files.  I don't need cad to open another cad hyperlink.  I know that one already.  What i need help on is my cad file to pdf file and having these links work to jump to the pages that i need them to go to.  I'm trying to attached my file but it's not allowing any attachments.
Message 16 of 16
CodeDing
For this, you should try Hyperlinking to a specific layout in your drawing:
This method successfully hyperlinked to another page in my PDF.
Best,
~DD
