hpdia0200w authentication error
Hello everybody!
Yesterday, I downloaded form Autodesk web page a copy of Autocad 2016 (Educational Version); after installation, the software ask me to authenticate the prodocut, so I've to login to Autodesk Account, but i receive the error "HPDIA0200W Authentication failed. You have used an invalid user name, password, or client certificate". From web page of Autodesk I've no problem to login. I tried to change password but didn't word. Can someone help me? Thanks to all.
stevetamplen
Hello andrea_ghila96, and welcome to the Forums!
Please check out this post:
https://forums.autodesk.com/t5/autocad-for-mac-general/authentication-failure/td-p/5679115
It describes the same error, so please look that over and see if that solution works for you.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Steve Tamplen
Technical Support Specialist
stevetamplen
@Anonymous
Did the linked Forum post help you solve your issue? If not, please do not hesitate to post back so I can continue to assist you.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Steve Tamplen
Hi I also have a HPDIA0200W problem. I tried to check how to transfer the licence to enable me to work from home & can not import the licence back into Inventor 2014. The version is registered to the company. any suggestions.
