Anuncios
How to wait for a command to execute
SaddamShaikh77
SaddamShaikh77
Hello forum,
I am trying to execute the command "doc.SendStringToExecute((string)button.CommandParameter + "PDFATTACH", true, false, true);" or "doc.SendStringToExecute((string)button.CommandParameter + "PDFIMPORT", true, false, true);"
// some code after this
I want to execute the above lines completely and the next code should execute. Now it is not working as expected. I tried thread.sleep, task, async-await, but couldn't work for me.
Document doc = aCAD_App.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
"ed.CommandAsync("PDFATTACH", true, false, true);"
This also not worked.(I am trying to attach pdf in empty document)
also,
Please suggest me any solution for this
0 Me gusta
Responder
Soluciones aceptadas (1)
770 Vistas
2 Respuestas
Respuestas (2)
Michiel.Valcke
If you are trying to make this a part of a macro, lsp, vba module or anything you will find help more quickly in the AutoCAD customization forums.
cadffm
Solución aceptada
For VBA we have a separately board.
https://forums.autodesk.com/t5/autocad/ct-p/8
And saddam is using .NET (if  i am right with this), for .NET API there is also a separately board available.
https://forums.autodesk.com/t5/net/bd-p/152
where saddam can search about his topic and start a new thread if needed.
Some interesting threads there like this
https://forums.autodesk.com/t5/net/synchronous-sendcommand/m-p/5574225#M43951
Sebastian
0 Me gusta
