How to use an existing polygon as a crossing selection fence?
kimia.salamo9881
kimia.salamo9881
You can select-> cp to draw a polygon to select everything within it. Is there a way to do the same thing using a polygon that already exists in the drawing?
OneCognizant.Cognizant.com Portal
imadHabash
I suggest to try FS (Express Tool)  .. also when AutoCAD ask you to select object, type ‘FS then [enter]. We use   for transparent use. Pick your object, then all objects touching it will be selected. also you need to learn more about FSMODE system variable.
FSMODE = OFF (default), it will select objects touching your picked object only.
FSMODE = ON, it will select objects touching it, and all objects touching them too.
Imad Habash
