Anuncios
how to unload a vlx ? or un-defun a command ?
No aplicable
How can i unload a VLX or undefine it?
using this file from here -https://payazed.wordpress.com/2015/06/02/xrp/
I've loaded a file called XRP.VLX through appload
I've tried to move it out of the original folder however the command "XRP" still remains and when it's typed/executed  CAD crashes/goes into the spinning wheel. Is there a way to remove it as a defined command?
Tom
0 Me gusta
Responder
Soluciones aceptadas (1)
654 Vistas
1 Respuesta
Respuesta (1)
imadHabash
Solución aceptada
HI,
you can search in your PC and follow XRP.VLX , then you can delete it OR while AutoCAD is active you can check your Startup suite from APPLOAD command >> Select and Remove .
Imad Habash
0 Me gusta
