How to transfer a command from the middle mouse button
nicolas_kalinin
Observer
nicolas_kalinin
Observer
Observer
Hello!
Help me, please.
How to transfer a command from the middle mouse button (which is on the mouse wheel) on space or another button on keyboard? I mean press the spacebar instead of the middle mouse button and move the drawing. Is it possible?
0 Me gusta
Responder
610 Vistas
7 Respuestas
Respuestas (7)
Patchy
Default the middle button wheel is for scroll and pan
Do you want to make space bar into Scroll and Pan?
0 Me gusta
nicolas_kalinin
Observer
Observer
I mean the pan command. How can I move this command to another button? So that I can use this command the same way as on the middle mouse button.
0 Me gusta
Patchy
If you're using customizable mouse, go to the mouse driver properties and assign autocad command into the macro.
0 Me gusta
nicolas_kalinin
Observer
Observer
Can I use a keyboard? For example, to hold down the spacebar to move a drawing, release the spacebar and the pan command will be aborted. Do the same as with the middle mouse button, only with a spacebar. I think it was done in Photoshop like this :cara_con_una_leve_sonrisa:
0 Me gusta
Patchy
It can't because space bar can't pan left, right......
Why not type in P for PAN?
0 Me gusta
nicolas_kalinin
Observer
Observer
You misunderstood me) Of course, I will move with the mouse, but instead of the middle button I wanted to press a key. I press the spacebar (or another key), move the drawing, release the spacebar.
0 Me gusta
pendean
Community Legend
Community Legend
You can turn off the middle button panning in AutoCAD with MBUTTONPAN system variable, look up usage in your AutoCAD's HELP.
@nicolas_kalinin wrote:
...I press the spacebar (or another key), move the drawing, release the spacebar.
In AutoCAD, that will not be the spacebar nor another button: that is already designed to do other things that you cannot truly override easily. What other drafting program do you come from?
If your Logitech or Microsoft wireless mouse (or keyboard) drivers have that ability, you can explore and try it there (but you'll always get that in all other programs on your PC).
0 Me gusta
