Anuncios
how to solve autocad 2021 version block file name uppercase to lowercase
weekhong1212
weekhong1212
Hi, All
how to solve autocad 2021 version when insert block file name uppercase to lowercase
0 Me gusta
Responder
Soluciones aceptadas (1)
703 Vistas
7 Respuestas
Respuestas (7)
BeKirra
Have you tried rename command?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
weekhong1212
Please dont disturb us.
0 Me gusta
weekhong1212
0 Me gusta
Kent1Cooper
@weekhong1212 wrote:
... when insert block file name uppercase to lowercase
Your image shows it not when Inserting it, but when Editing its Attribute.  Does it also appear that way in the INSERT dialog box?  And when you type this at the command line:
  (tblsearch "block" "test")
[replace test with the desired Block name], what is the case [or combination] of what it returns?
  ((0 . "BLOCK") (2 . "TEST") ....
And is it the same as the way it appears in the Insert or Attribute Editor dialog boxes?  And is it the same regardless of what case combination you type in?
Kent Cooper, AIA
0 Me gusta
weekhong1212
Hi, Sir
thanks for you reply, i have attached 2 video for you refer.
1. Single Click & insert (Become Lower Case) = Wrong
2. Click & Hold (As normal Upper Case) = correct
0 Me gusta
Edwin.Rense
Solución aceptada
What happens when you use the CLASSICINSERT instead of the 'new' insert palette?
Do the cases also change?
I don't see this happening for me. What i do see in your screencast is that AutoCAD gives the block definition duplication error.
What happens when you perform the same thing in an AutoCAD template? Does it still change?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
0 Me gusta
weekhong1212
Hi, Sir
you are right, i use CLASSICINSERT dunt have this type of issue.
thanks for you info.
0 Me gusta
