- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, All
how to solve autocad 2021 version when insert block file name uppercase to lowercase
¡Resuelto! Ir a solución.
Hi, All
Have you tried rename command?
Please dont disturb us.
@weekhong1212 wrote:
... when insert block file name uppercase to lowercase
Your image shows it not when Inserting it, but when Editing its Attribute. Does it also appear that way in the INSERT dialog box? And when you type this at the command line:
(tblsearch "block" "test")
[replace test with the desired Block name], what is the case [or combination] of what it returns?
((0 . "BLOCK") (2 . "TEST") ....
And is it the same as the way it appears in the Insert or Attribute Editor dialog boxes? And is it the same regardless of what case combination you type in?
Hi, Sir
thanks for you reply, i have attached 2 video for you refer.
1. Single Click & insert (Become Lower Case) = Wrong
2. Click & Hold (As normal Upper Case) = correct
What happens when you use the CLASSICINSERT instead of the 'new' insert palette?
Do the cases also change?
I don't see this happening for me. What i do see in your screencast is that AutoCAD gives the block definition duplication error.
What happens when you perform the same thing in an AutoCAD template? Does it still change?
Hi, Sir
you are right, i use CLASSICINSERT dunt have this type of issue.
thanks for you info.
