How to slice this 3D object in AutoCAD
I'm trying to remove everything below the red line, regular old Slice command isn't doing the trick, thanks
@Anonymous,
john.vellek has edited your subject line for clarity: How to slice this...
john.vellek
Hi @Anonymous,
Have you considered making a rectangular solid and subtracting it?
I will take a look at your file but you might consider trying that in the mean time.
John Vellek
I tried that but got an error message, thanks
Have you tried slice with 3 points?
I tried it with the file you attached I could separate the desire part of the object, how ever patience is necessary due to the fact that sides are not perpendicular to each other.
Another way is to extrude a shape similar to the red one you drew and then subtract.
