AutoCAD Forum
How to simulate AutoCAD 2024 3D model files with AUTODESK CFD 2024
2 REPLIES 2
s1290164
236 Views, 2 Replies
I am currently a licensed student.
I have installed AutoCAD 2024 and created a 3D model.
When I installed AUTODESK CFD 2024 to simulate the environment of that model, the AutoCAD 2024 file could not be sent.
Therefore, I was able to install AUTODESK Inventor Professinal 2025 and am trying to import data with it.
However, it is very large and cuts off in the middle.
Can you please tell me how I can use the AutoCAD 2024 3D model files with AUTODESK CFD 2024?
2 REPLIES 2
vladimir_michl
in reply to: s1290164
Depending on the type of your 3D model in AutoCAD, you probably won't need Inventor. Just export your DWG model to the ACIS format (.sat). In CFD, create a new study, load this .sat file and specify units.
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
s1290164
in reply to: vladimir_michl
Thank you for replying.
I will try it in the way you described!!
