How to show blocks while insertion
Karol-Or
Karol-Or
I use INSERT command but until i don't select an insertion point i don't dynamically see the block, so i don't know how to orient it
0 Me gusta
Responder
Soluciones aceptadas (1)
467 Vistas
6 Respuestas
Respuestas (6)
john.vellek
Hi @Karol-Or,
The normal INSERT command will not show a preview  in the dialog such as Design Center does.
However, it should show you a preview when asking for an insertion point. Is it not doing this for you?
John Vellek
0 Me gusta
Kent1Cooper
Do you have DRAGMODE turned off [the System Variable set to 0]?  Set it to Auto [System Variable 2].
Kent Cooper, AIA
Karol-Or
There is no preview during insertion even with DRAGMODE on.
Now i see that if i uncheck the Explode option in the INSERT dialog it is shown. this is on Acad 2006, i didn't check it yet on 2013
0 Me gusta
imadHabash
that is true.. when Explode is ticked you will insert non block items,for this you will not see any block preview.
Imad Habash
0 Me gusta
Karol-Or
Is there a way to see the block preview without Explode ticked?
0 Me gusta
imadHabash
Solución aceptada
When your block is exist ; select it then right click then go to addselect command.
Imad Habash
0 Me gusta
