How to Set the VP Color and VP Lineweight to match the layers' colors and lineweights?
elysia_12
elysia_12
Hi! Just wondering if there's a way to NOT let any override on the actual color and lineweight set on the layers? Or at least set everything the same as one color and lineweight for each layer? Not really liking the override feature. Hope some CAD expert could put a light on this. Thank you very much!
0 Me gusta
Responder
604 Vistas
3 Respuestas
Respuestas (3)
tcorey
Once you set the layers, use Layer States to save the settings for restoring later.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
0 Me gusta
cadffm
Select all in layer palette (while inside your viewport)
Rightclick to open the context menu, remove overrides..
Sebastian
mgarcesUX9HW
for me layer color is important while working, you can set your plotstyle to desired color and line thickness and modify your page setup to display plot style :cara_con_una_leve_sonrisa:
0 Me gusta
