how to set the unit
how to set the unit
how to set the unit
I've tried 'drawing utilities' -> 'units' and set the unit to micron under 'insertion.' (image1)
Then, when i typed in 'dwgunits' in the command line, I noticed the unit was still set to 'inches' (image 2)
I need to set the unit to 'micron' but I wasn't able to see how you would do it.
Are we really stuck to having just 6 different units available under 'dwgunits' ?
imadHabash
This is because INSUNITS (System Variable) is different than -DWGUNITS command.
Yes , AutoCAD have only ( for Now ) those 6 units options .
i suggest to try to draw your lines in a certain unit then insert it in a new empty drawing with  INSUNITS = 13 .
Command: INSUNITS
Enter new value for INSUNITS <13>:
Imad Habash
cadffm
Please: If you really talk about plain AutoCAD and new drawings/templates: Do never start -DWGUNITS in this file unless you know what you do.
Create your template based on standard acad.dwt/acadiso.dwt (or without a template) and change your INSUNITS (thats the "Unit" of _units dialog).
But do not start -dwgunits and save the filesession. (it would write useless information in your file and force (useless) alerts and problems without a need)
Sebastian
