How to select lines vs. polylines?
No aplicable
Am using Autocad 2016.
When there are many elements at the same location, how can one cycle thru them?
For example, a floor plan has a polyline all the way around the room, with normal lines at the same locations.
Say when using the Presspull command, how can one tell Autocad to select the line instead of the polyline?
Thank you for your help.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.884 Vistas
9 Respuestas
Respuestas (9)
john.vellek
Hi bruce4444,
Selection cycling is probably what you are looking for to resolve your issue.  Also, you might consider keeping the polylines on their own layer so that you can select them more easily by isolating them or by freezing and/or locking other layers.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
0 Me gusta
kennyj
Hello Bruce4444, Several options here: 1) use layers for types; if you have boundaries for areas (Polylines) then put them on a layer so you can select by layer. 2) Use the filter command; select, filter and chose lines vs polylines 3) You can cycle through the objects that lay on top of each other. Here is a link to an article on doing this since the way to cycle depends on your version of the software: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to... Hope that helps! Kenny
0 Me gusta
No aplicable
How can one do selection cycling?
0 Me gusta
john.vellek
Solución aceptada
Click on this link for Selection cycling to see how you might use it.
John Vellek
0 Me gusta
GrantsPirate
I just tried SC with lines on top of plines and when using PP and selecting on top of the two objects SC does not kick in. SC works with other editing commands but not PP. Release 2016.
With SC on, click on top of the lines, pick the pline from the list, right click to bring up a menu, pick Draw Order, Bring to Front.  Now PP will get the pline.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
0 Me gusta
rkmcswain
You should report this bug. No reason I can see why SC shouldn't work here.
0 Me gusta
john.vellek
Hi GrantsPirate,
I think you might be right! When I try it and try to cycle through the elements, the PP command actually cancels. Your method for using SC also works great though and provides a nice workaround.
At any rate, I would never have the patience to cycle through objects. I would merely isolate or freeze things until I only had displayed the exact objects I with which I wanted to work.
Old-school I guess. Thanks for your suggestions on this thread.
John Vellek
0 Me gusta
rkmcswain
Using the Ctrl key? Won't work since that has special meaning during the PressPull command.
See the text under "Methods for Press and Pull Modifications"
0 Me gusta
john.vellek
Hi bruce4444,
I am checking back to see if my post or others has helped you with your problem. There are good workarounds mentioned as well as identification of some of the limitations in Selection cycling while in this command. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
