How to reset (left/right) Mtext Justification after Mirroring floor plan
daveshepherd
daveshepherd
Hi All,
I just mirrored a floor plan and the Mtext had been set to the left justification. when I mirrored the floor plan the Mtext
is still set to the left. My question is: Is there a command that will allow you to highlight all the left justification Mext and change to the Right Justification. Maybe some sort of filter command?
Dave Shepherd
Northern California
atGK8NU
Use the QSELECT command, and filter with the Justify property.
daveshepherd
Thanks for the quick response, but unfortunately, I tried that command
early but it didn't work
pendean
Community Legend
Community Legend
Is that really a floating Mtext 'scooched' next to a floating leader?
If it's an MLEADER instead, you can try fixing it like this manually
Or permanently fixing your MLEADERSTYLE settings forever in all of your files including this one like this:
HTH
atGK8NU
If it is indeed multileaders in your drawing,  that would explain why QSELECT didn't work for you... Multileader needs to be specified as the object type.
If not, please share your drawing if possible.
